Has anyone tried to swap power folding mirror internals from non-m coupe mirrors to m3 mirrors? I know you can swap m3 internals between each other fairly simple but wanted to see if anyones done the former
M3 Power Folding Mirrors question
This post made me curious and I found previous threads on this. A guy on YouTube even made a tutorial for it using oem parts as this was an option for individual optioning. Just need to disassemble the housing and insert the proper motor and connect it with new mirror switch that will have an extra button for folding, pretty cool, kinda extensive process though and motor isn’t cheap.
[DIY]Converting Manual-folding M3
Mirrors into Power-Folding Mirrors
You can use the motors from the eBay M5-style (for 98-03 E46 2D Coupe) to transplant into the OE M3 side mirrors. The wiring is short and you will have to lengthen them but otherwise they will work fine.
Converting Manual-folding M3 Mirrors into Power-Folding Mirrors Requirements: ⢠Manual folding M3 Mirrors ⢠Donor mirrors with compatible motors (another set of M3 mirrors; E39 M5 mirrors, and M3/M5 replica mirrors (YMMV with those â I donât know if all molds are the same) ⢠T15 and T20 bits ⢠Optional but recommended: Blue Loctite (ideally 243 as some parts are greased) ⢠About 1-2 hours depending on how much experience you have. This DIY is useful for two groups ofLast edited by WOLFN8TR; 06-02-2022, 12:03 AM.TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
Evolve Eventuri - VIS XTS CF Hood - CF Lip/Console/Diffuser/CSL Trunk
