Hello folks,
i have finally did a “long” trip yesterday with my 3 year old where i put the most miles on the M after the kids. 600 miles in one day where it was 105 outside…Maybe not the best choice for a black on black convertible…i had an aux fan for back seat
So, i have a 2006 m3 at 113 miles, since last 6 years, i barely driven the car 3000 miles in total… I would get check engine light randomly, engine not reaching target temp and temp gauge will be a little below the middle..when it is really cold in Winter i would see some coolant leak. So after every bard winter, i would top off the cooling system
Before this trip i decided to change the thermostat and temp sensor and replace all the o-rings and gaskets in the cooling system and flush the radiator, drain the coolant without removing the engine drain plug ( since i could not reach it and gave up).
i pressure tested the system, test drive for a week or so, roughly 200 miles. All looked good. Temp gauge dead right in the middle, check engine light cleared it self… i am very happy, right… up to this point i have never seen temp gauge moving upwards on this car, since 8 years!
so we start the trip yesterday, within first 15 min, i see the temp s moving a little upwards beyond the middle( almost reaching 3/4) and coming down again. Over the course of the drive it, i have observed this coupe of times…
i thought well it is so freaking hot and i need clean air…we managed it make it to our destination without any problem.
it did it again today when it was “only” 92 outside during a short drive… i was about to arrive home and parked in front of my yard and watched the temp gauge to see if it will continue rising… nope come back down in the middle once again…
i am so sorry for the long backstory to this…
Where did I fail?
or am i in trouble?
Is this something normal?
Is my water pump failing, or should i think replacing of the balast and upgrade it to Electic fan?
FYi, i have not seen engine oul temp rising above 210…
Thank you all, have a great night
Where did I fail?
or am i in trouble?
