Was driving home on the freeway tonight and after I exited I realized I had no power steering. Pulled over at a gas station down the street from my house and I could see it had all dumped out on the pan. I've never had a problem with it, except a leaky reservoir until today. Checked fluid regularly. Have no idea when it started leaking on the drive and I didn't hear or feel anything different until I slowed down. Drove to my house about 2 blocks away and put it up on the ramps. Found the leak in the high pressure hose and ordered it immediately. Gonna do a flush before installing it, but my question is how likely is it that I need to order a new pump?
Power Steering Fail
Agreed the pump is probably fine as long as there was some oil. You will hear a whine when you turn the wheel if the pump is bad. You could also open it up and check the internals of the pump for damage if you wanted to be overkill. Recently wrecked my PS pump when the reservoir melted on track and plastic got pulled through it which scored the internal rotor. Even then there was only a slight whine under load so they are pretty robust.
Pump is 100% fine. I had that same thing happen to me on a trip to Austin few years ago, and I drove home to DFW for like 300 miles without PS. Once I replaced the hose and put new fluid in, the car was fine for years after.BMW / E46M Interior & Trim Restoration.
So just as a follow up to this thread, I did end up replacing the line and all has been "sort of" well since. The pump sounds mostly normal with only a very light whining when turning the wheel. However after checking the fluid a few times I can see tiny metal flakes in the reservoir when shining a flashlight. I'm assuming this pump is toast. I definitely don't want screw up the rack and pinion so should I just buy a new pump now before things get worse? Appreciate the help!Last edited by 174bpm; 08-13-2022, 07:35 PM.2004 E46 Imola Red M3 Coupe
2015 F56 Pepper White Mini Cooper S
2018 W205 Polar White C300 AMG Night Edition
