Anyone else remove the rear sway bar?
    One side effect from no rear bar is I get more inside front tire lift. It looks cool! I definitely lift the inside tire more. Not sure how detrimental lifting the tire is, I'm sure there is a loss of overall grip.
    Here I'm on the throttle. This is a common place for photographers to shoot. I've never seen the left front tire lift before removing the rear sway bar.
    Spring rates?
    2003 Imola Red M3 w/ SMG
      Originally posted by K-Dawg View Post
      Spring rates?
      450 front and 700 rear
        If you're serious about tracking then having linear potentiometers on each shock would tell you a lot about where you are in the travel during corners - whether you're reaching the droop limit or whether swaybar is lifting the inside wheel, and where you are relative to the bump stops.
        That's how I deduced that my car was swaying way too much without the rear sway and those soft rates.
          I'm gonna do this just so I can snap a pic like K-Dawg. I will report back on how it actually feels when completed. But feel is secondary to the pic at this moment in my life.
