A/C Diagnostic help
    A/C Diagnostic help
    Hey guys, need some help troubleshooting the A/C. Long story short, replaced a lot of the smaller bits (expansion valve, dryer, o rings) and tried to recharge the system. I even replaced the heater valve under the intake manifold.
    1 - Pulled vacuum for 2 hours and gauges hold vacuum overnight, so no leaks.
    2 - Put 1 can (340grams) of refrigerant in while car is off. PSI was around 70 on both low and high side.
    3 - Turn car on and run AC full blast while can 2 is hooked up. Very little refrigerant is being drawn, low side PSI continues to climb near 100psi and high side barely reaches 125psi.
    Compressor clutch is engaged and spinning, but the PSI differential between low and high is minimal. Compressor doesn't cycle and runs 100% of the time (with AC on, it does stop if I press the snowflake). My feeling is the compressor is shot, even though spinning it by hand doesn't produce any noticeable bad noise. I also don't understand how maybe 400grams of r134 is causing such high PSI readings on a system that can hold 740grams of r134.
    Thoughts?
    Also, in INPA what is the 'additional heater' referencing?
    From what you are describing, with the low and high side close in pressure, indicates a bad compressor.
    2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 288/280 Schrick Cams+DLC Followers | Lang Head | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 400/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | Turbo Toys V2 Hub | WPC Rod Bearings
      Just seeing this but you were correct, turns out the compressor was toast. Quick swap and blows like she should. Thanks!
        Glad to hear you got it figured!
