Alternator Options
    A multimeter won't really give enough detail for show a bad diode. Basically it can be detected by looking at the ripple on the output which will be what the tester is looking at. Cheap battery testers often can do a ripple test.
    If you put the meter on AC volts, what do you get?
      I took it back to autozone today and had them connect the tester to the battery directly. Both battery and alternator came back good.
      2007 Imola Red Z4M Coupe
        So just to add a data point:
        My original alternator died at 195k km.
        I guess I didn't do my research at the time because I went with a Bosch reman from FCP Euro but it's still running fine 5 years and 20k km later. Time will tell I guess.
          I think the bosch alts, in my own experience and seeing others', either are bad pretty much immediately, or you get a good one that lasts. It took me 2 duds initially, but my 3rd bosch reman has also lasted me the last 5 years or so.
            According to FCP the M3/Z3 Valeo are discontinued. Shocking ! It is too early for these things to happen. There are still plenty of these cars on the road.
              I got mine from Bimmerworld: https://www.bimmerworld.com/Alternat...831-436_2.html
              They were out of stock then came back in stock recently. Maybe its discontinued just at FCP?
                There are plenty of them online in stock around the world. No need to worry. Im sure they'll be back i stock at FCP sooner or later.
                  I bought one here in Europe last week, was freshly made, not some old stock. Pretty sure FCP is just wrong.
                    FCP going downhill
                    Youtube DIYs and more
                      FCP probably not liking the price or contract terms they can get for them to allow them to warranty.
                      I often wondered if FCP returns the warrantied items back to the manufacturer. If not where do they go?
                        PSA: Just got notified that Bimmerworld has the Valeo units back in stock if anyone is looking for one:
                          I’m sure they do whenever they can.
                          Id be inclined to buy a BMW reman from the dealer. Limited lifetime warranty.
                          If the dealer installs a BMW part and the customer pays something then there is a 2 year parts and labor warranty.
                          BMW provides a limited lifetime warranty on specific parts - IIRC, it’s alternator, water pump, starters, ac compressors, shocks and struts. Might be a few other things. This warranty covers the part only.
                          Talk to you dealer first but you’d need to show the failure. Typically a screen shot of the fault code works, just depends.
                          I’m thinking about getting an OE alternator and keep my Bosch as a spare.
                            Originally posted by whoissuprme View Post
                            I was away for a little bit and the car is still at my buddies shop. I will be going there tomorrow (10/13/22) and will take measurements on the pulley diameter to make sure it's the same. While I was swapping in the new alternator I decided to swap out all the pulleys with new ones and do a belt service and a new clutch fan. Stay tuned for more info. I'll report back with my findings!
                            Any updates?
                              Any updates?
                              its a 55mm diameter pulley same with any M/S 5x motor..
                              as for the alternator, any m54 alternator should work if you switch the back cover.
                              I ran a 90amp(less drag) version in my E36/S54. For an e46 120amp+ unless you have A/C,radio etc. electronics deleted.
                                Thanks for the feedback. I am not sure whether to stick to the 120amp or go to a 140/150Amp alternator. In our summer with the AC blowing and 125F+ plus high humidity the aux fan running at full speed the 140/150 Alternator might be a better choice?
                                Then again never had issues with my original alternator until now, the battery monitor today shows its making 12V instead of a Minimum of 13V up to 14V+. I am sure the alternator is on the way out.
