Subscribing to this one--I'm getting these exact same codes on my stock cats, hence the motivation to go with this SS system. Hoping I didn't waste the $$ on the cats when the post O2s ultimately need turned off anyway.
EDIT: Came across an interesting thread on another forum where a Z4M owner had issued with his SS system due to EGT placement--more so power delivery and the ECU activating cat protection. Not sure if that's related here to this issue, but does raise the question: on our cars, EGT should be relocated to Section 1, or used in the header? SS apparently provides locations for both.
P0420 & P0430 codes at same time with new supersprint cats
I'll check out VeePeak and OBDFusion and let you know!
The cats are HJS units supplied in Supersprint's section 1. Surprised the codes would have come in at exactly the same time for both cats if one of the cats was doing a poor job.
Are the car stock or aftermarket units? The codes say the cats don't do a good job to clean the pollutant -- the DME detects abnormal post cat sensor signals.Originally posted by mcfreid View PostInstalled supersprint headers and cats last winter. Replaced all o2 sensors at the same time. I've put on about 1k miles on the car since then. Today the service engine light came on with codes P0420 and P0430 at the same time..
Can you collect the data in the log file, using OBDFusion with the following parameters at warm engine idling: rpm, MAF, coolant temp, precat O2 and post cat O2, FTFT and STFT for both banks.
I use VeePeak dongle for the OBD port, and OBDFusion app on iphone.
Just how it is. It's always low load highway cruising that throws the light for me. I've tried turning down the secondary O2 thresholds multiple times but got tired of the codes continuing to appear and just turned them off. I would recommend you do the same.
Could use some help on where to look first. What are your thoughts?
FYI: also recently replaced the engine air filter, if that matters at all.Tags: None
