  • PSUEng
    Got mine today, looks good! I'll lay them out to relax the rippling, I'm not going to do this job for a while.
  • Nate047
    Ditto, it will come.
    Yea I'm not really worried, just kinda like uhhhh hello?
  • Maxima SE
    maybe a hairdryer or direct sunlight will help with the rippling?
  • Cubieman
    Got mine, same rippling effect, likely due to being stored balled up, all in all pretty badass to have something that looks like the real deal.
  • WestBankM4
    I still haven't received even a confirmation of my order or anything from him.
  • Casa de Mesa
    Mayan-Viking calling this to your attention...
  • Nate047
  • 0-60motorsports
    Received mine today too
  • BMWE46M3
    Thanks for sharing and Go Bills!
  • T.J.
    got my pieces from the group buy today. They seem nice besides the bacon-ing. Hopefully that goes away when installed
ID:	222746 Click image for larger version
  • PSUEng
    Good info what brand do you recommend?
    Here's some photos of my Brand New lower trim pieces. It almost looks like they need to be wet sanded and then coated. For $35 each I will try to “clean” them up a bit before using them. Glad they weren't the ones for $125 each!
    That's what mine looks like. I've dabbled in different brands--Griot's, Pinnacle. I went through this expensive detailing products phase but end up back at the basics. Any decent brand is probably fine--the chemistry is likely all similar. I think clay is where one could spend money, and actual coatings; but the spray stuff, likely all similar.
    EDIT: I hit the part with various mild-medium cut polishes/swirl removers using an orange foam pad (light cut) and it cleaned up the residual mold release/residue. But the faint "lines" won't go away so I may hit it with 0000 steel wool and a quick detailer/clay lube. The vendor I purchased from just refunded me the money so I can use this an experiment of sorts.
  • WOLFN8TR
    Cool thanks!
  • oceansize
    Meguiars Ceramic Detailer, Turtle Wax Ceramic or Graphene, Mothers, etc. Doesn't need to be anything exotic in my experience. 303 every now and again is fine to.
  • WOLFN8TR
  • PSUEng
    The ceramic and graphene spray on coatings appear to do a nice job of preserving rubber. I've been using it on my daily's rubber trim for seven years and the rubber is absolutely mint. Should be noted that my daily is not garage kept. I'm only wondering if the rubber will now rot from the inside out.
    I've used 303 and SiO2 spray on rubber as of late, so hoping that keeps my trims looking good if this is the kind of quality replacements are out there. These horizontal "gasket rails" have shot up in price too; now they are expensive poor quality parts.
