Strut Mount and Camber Plate Comparison
    I just installed the Ground Control hybrid plates. It was a little weird and required some emails to support, so I made a quick video how everything goes together. Hopefully a good addition to this thread: https://www.youtube.com/watch?v=22dnrlga4is
      thanks for this. would like to hear your feedback on them. any noises, clunks, weirdness driving around town?
      🔹 2001 M3 Laguna Seca Blue
      Instagram: link
      Build thread: link
        I got it aligned and corner balanced today and my next track day is tomorrow, so I only have feedback on the installation and street performance:
        • There are definitely some new pops and clunks during parking-lot-speed maneuvers
        • At speed, there is really not much difference for most bumps with one exception: rumble strips are INCREDIBLY LOUD.
        • Setting the alignment on the front was a huge pain. Despite what the GC website says, there is no way to access the camber bolts without at least loosening the strut mounting bolts. Minor trackside camber adjustments are absolutely not an option.
          I wish more people made informative videos like this. My observations:
          -I think you installed the springs right, it's better for the helper spring coupler to hit the metal before coil binding the helper so it doesn't cock to one side. In reality unless you're jumping your car you will probably never actually extend the helper spring except when working on it. Otherwise I'd be worried about it getting caught on the edge of the body.
          -Very weird you had to modify the threaded portion to fit the swaybar mount, kind of an unfortunate oversight by GC. Would it be feasible to stack washers under the adapter to raise it up so no modification is needed?
          -Did you compare the stack height of the GC camber plate to the stock one? Despite the threaded adapter taking up some length, I think it's also shorter overall so hopefully you didn't lose travel with these parts?
          -You might want to consider running the BMW reinforcement plates since the GC plates put all the forces through a smaller area than the stock mount.
          -The main spring does not look like it has very much travel. You should check that it won't coil bind given your travel and ride height configuration.
          -Check your bump stop position relative to the body at ride height. You might find that it's touching or nearly touching.
          I have these same GC plates. I was worried about added NVH but didn't really notice much. I didn't like that for a near-stock alignment setting, the adjustment is all the way at the limit. Eventually went back to stock.
            Ok, can confirm the ™ Hybrid plates will work with a 60mm GC spring perch, which means you don't need to shell out $185 for a 2.5 from them.
            Can also confirm, the hybrid plates are made in china/taiwan now, the brittle plastic wrap they come in gives that away easily…
            Thanks for blazing this trail for us. Follow-up question for you as I have a pair of TMS Hybrid plates on the way and need perches for my Ohlins.
            Did you buy the GC Street, Street Hybrid or Race perches? Did you pair them with the TMS bearing or did you buy a GC bearing?
            If helpful, here is a link to the GC street perches: https://groundcontrolstore.com/produ...7725999f&_ss=r
              I went with a 60mm street perch for use with my H&R springs. However, I also bought the other spring diameter options, because I have not run these springs yet, so can't comment on that.
              I currently have them installed with a BMW bearing, though I believe they are the same dimensions as the GC, the BMW unit is a very tight fit
              Sent from my iPad using Tapatalk Pro
                I've installed GCs on a few cars and not everyone makes noise, but of all the cars I've installed camber plates onto its the GC ones that make noise... and primarily its popping with low speed turns. We generally don't install GCs anymore.
                Right now we put:
                -Vorshlag on track focused cars.
                -TMS on street cars that need more camber OR planning for the future/don't want to buy stock when you can buy these at a similar price.
                -Stock on "OE" cars.
                Curious if your thoughts have changed on this? Just took delivery of my Ohlins R&T and need to pull the trigger - OE strut mounts seem to be unavailable. Currently stuck between Vorshlag, Turner street and Millway (car is daily/street driven with one or two track days per year). I feel I have a reasonable tolerance to minor NVH things but still, would like to keep the car as quiet and comfy as reasonably possible for occasional drive from Austin to Dallas
                  U00215-01
                  U00216-01
                  I've had my Ohlins for years and have ZERO noise. IDK why people resort to cheap Chinese crap for camber plates on this vehicle.
                  2004 Dinan S3-R M3
                  2023 X3M Competition
                    U00215-01
                    U00216-01
                    Which camber plates are you running?
                      ... Ohlins.
                      I just listed the part numbers.
                      2004 Dinan S3-R M3
