Recently I've noticed that in gear, on/off throttle, I get a clunk/thud from the rear end. It's worse in Sport mode, and worse during shifting unless I slip the clutch a little prior to lifting off the throttle. Searched around and I can't make out the "M-clunk" vs. any other problems from the thread results, so apologize in advance if there is a thread already.
My "hunch" is, driveshaft u-joint. The entire driveline is original at 81k--visually, the guibo looks good last time I was under it a few weeks ago fixing the CPV. I'm going to get the rear end up this weekend and attempt to do a few inspections on the driveshaft (excessive play) and attempt to check the axle CVs for play.
What do you guys think? If it's the driveshaft, I like a complete rebuilt solution like the Beyer.
