Like the title says, I'm about to reinstall my transmission and cleaned the splines but would like to know what I should apply to the splines? I'm assuming some kind of high temp anti-seize, but I may be wrong and am looking for some advice. Thanks guys...
What kind of lubricant should I use on the transmission input shaft splines?
I was able to determine the correct lubricant to use and wanted to share with other if you need it down the road. It's Sachs Clutch Disc Spline Grease (part # 4200080050) https://www.fcpeuro.com/products/clu...chs-4200080050. And here is a video of how to apply it. https://aftermarket.zf.com/us/en/sac...he-hub-spline/
