Adjustable rear control arms and camber plates
    Car is on ohlins and stock hats want get some camber plates and adjustable rear control arms.
    Car is street and hopefully auto x. No tracks around me. Just mtn roads.
    Sent from my Pixel 6 using Tapatalk
    Ground control or Turner "street" plates
    SPC alloy aka Eibach arms with rubber. I think Turner makes some too (think there's even an "ECS" branded one), but you want alloy arm with rubber bushing. Most have solid bearing.
      I'm personally a big supporter of bearing mounted lower camber arms. Why do you feel rubber is best?
      From my perspective, they don't increase harshness as cornering forces build slowly as the car rolls, springs/bar load up etc. The lower arm also experiences about double the force (in the opposite direction) of an upper arm in double arm setup so in terms of geometry consistency removing rubber in the lower is far more effective.
      There's also reduced suspension binding as the bearing's don't add torsional force when hinging.
      If you don't mind me plugging my own Tones, I've pasted a link. They're aluminium construction with camber adjustment made with a stainless steel jack screw at the wheel end which makes life easy.
      Fits: All E36 & E46 Non-M, E36 & E46 M3 (excluding E36 hatch). Benefits:-Increases rear camber adjustment (Suspension Tune-ability)-Adjustments made at the wheel end of the arm (practicality)-Provides consistent camber geometry (stability)-Free pivoting spherical bearing (no suspension binding)Note: A bearing m
        https://cmpautoengineering.com/colle...le-camber-arms
        Right on. Love your stuff. Looks well priced to. You make it in shop also?
          Thanks mate! I do my best to offer top quality at a competitive price.
          I outsource all cutting, folding, powder coating, machining etc. I assemble & package everything myself in the workshop.
          If I can x10 my turnover, in house CNC machines become worthwhile. I'll keep trying to make it happen
            The CSL "camber arm" comes with a bearing.
            This for me was enough justification to disregard any rubber options. I went with the ones from CMP as linked above.
              There's no free lunch. I don't much care for people's opinions on the NVH effect, it's too subjective. For a street car, rubber is preferred.
              BMW used rubber. I've been around long enough to see the full circles we've gone around in from stock to modified, back to stock.
              No offense (I like your products), but you are a businessman, so your opinion is extremely biased. I'm not actually saying you're wrong. I've been though 20 years of businessman posting about products on forums, and what do you know? They were largely wrong (again, not saying you are absolutely).
              This is a forum. OP asked, so I answered. You can answer, anyone can answer. OP can make up his mind.
                Why? What's your alignment look like now?
                2003 Imola Red M3 w/ SMG
                  Sadly the genuine CSL rear arms went NLA a long time ago.
                  I have used the TMS rear camber arms for about 8 years. They are actually the race kit as apposed to the street version.
                    I went from stock to the BW monoball bearing rear camber arms last year and didn’t notice any NVH increase. Also running Ohlins R&T.
                      No offense taken. Thank you for sharing your thoughts.
                      I agree that many people selling a product (often on selling someone else's) will tunnel vision and blatantly ignore facts to push what they offer. It makes watching other peoples 'builds' on YouTube very hard to watch without cringing.
                      For that reason I understand why people stay in their comfort zone and can be sceptical of new ideas as there's plenty of misinformation out there.
                      I'll admit I was hoping there might have been a technical reason I may not have considered. My thinking can tunnel vision towards my own function objectives so I like to hear how others think to be more considerate of a broader communities needs when designing things. (new reinforcements being an example of this).
                      For what it's worth, I try not to push my own products but present the facts for what they are and let people make that decision for themselves. I did plug it because I felt it best answered the question to the problem however, whether mine or any other brands I would still be suggesting a bearing mounted lower arm.
                      I had complete design freedom when I designed mine and could have designed for a stock rubber bush (which would have been cheaper) however, I did make that decision for a reason. As BMWfnatic said, the engineers at BMW must have gone down the same train of thought arriving at the same conclusion which lead to the bearing mounted lower arms in CSL's. (If only they experimented with solid mounting the subframe bushings then to!).
                      I'm always happy to answer questions or better explain things if there's any part of the function you'd want to ask about. I've been wanting to write an article explaining how NVH works to helps people make informed decisions when building their cars as so often products are pushed on people without the reasoning to back it up. It think it would be a big help to the community to build something to their goals and desired level of compromise (as you said, it is subjective) rather than being told to blindly following the opinions of others.
                        Camber plates - there is one option IMO - Vorshlag.
                        Rear camber arms - I’ve used Turner with no issues.
                          I would love to be able to run spherical bearings suspension parts on the street but here in Quebec, Canada, it’s impossible cause roads are terrible.
                          I did it in the past on a ZCP built track car. Was driving the car to the track. Second event, wasn’t even at the track and something felt loose in the rear. The Rogue Engineering sphericals in the camber arms got a loose in the teflon liner…
                          Same thing happened with Turner Motorsport race camber plates…
                          Lesson learned for me, street = rubber, track only = sphericals!
                          GT4 Composites
                          2003.5 BMW E46 M3 Laguna Seca Blue / LSB 6mt
                          2006 BMW E46 M3 Estoril blue / Black 6mt
                            That is a big issue with sphericals and the grime they're exposed to on the road. Here in Aus we don't get salted roads as it doesn't snow in 99.9% of places.
                            I wonder how the longevity would be improved if using rod end boots. It's a rubber boot that slips over the whole rod end to seal the bearing surface from the elements similar to OE ball joints. I offer them on all the spherical products I offer.
                              Problem here are pothholes, not road debris.
                              GT4 Composites
