To start the car is on a Syvecs standalone, so no codes, just looking at data.
I am having an issue with the intake cam sticking intermittently. It will lazily move to its target position, then not return until seconds after. The picture below is 2000rpm-5500rpm log, yellow is the target, purple is the actual position, and blue is the duty. It increases duty to try to get it to move, which it does slowly. Then it increases more towards the end for no apparent reason, then does not return to the target after. The solenoid, vanos seals, and diaphragm springs are all new. The exhaust cam is also working fine.
I am out of ideas on what the issue is, so any suggestions would be greatly appreciated. Thanks in advance.
