Found this in my undertray in a small section near the radiator on the left hand side (ie at the front on driver's side in LHD)
I had the undertray off recently doing coolant so seems like it hasn't been there long but not sure I'd have tipped it up that time. I did give everything a super clean in the past 12 months or so, so could only be there that long at most.
It's fairly firm rubber. I was thinking it may have been something from the stock air filter box and how it mounts on the rubber "bar". There is a hole in the bottom of the airfilter box that's a bit small but I presume that's to allow any excessive moisture to drain.
It may have fallen off something in today's exercise which is valve cover gasket (unlikely related as it's too far away) and replacing the tensioner pulley so have airbox, stock mechanical fan and shroud etc out.
Any ideas? Can't find anything in RealOEM.
Thanks
Thanks
