Cam Bearing Thrust Plate Torque
    Hi all!
    These are M8 bolts with a spring washer. There are 5 of them. I could not find the torque spec in the TIS. Looking up online tells me M8 should fall between 28-32NM. This seems terrifying-high as they thread into aluminum. The spring washer tells me they need less than that...
    Does anyone know?
    Image is attached for reference. many thanks!
    Check the important link at the top of the forum - there is a pdf file for torque spec on all fasteners.
      Yes, it's a great link, but this bolt spec is not in there. Here is the relevant page from that link - similar to what I posted above. Unfortunately, no mention of it.
