any update on your manual swap?
i was having the same issue as you. got a new clutch, slave, fork pivot pin etc all replaced and still no start. like Sapote said i checked the wiring harness. no obvious leaking at any hydraulic line. through inpa the only error was code 59 which a year ago was resolved with a new slave.
i also was able to start the car with a disconnected plcd sensor.
one thing to note is that before installing the new clutch, the car would only start and stay in Neutral with the PLCD sensor disconnected. i was not able to go into any gear. after the new clutch was fitted , i was able to then select gears with the plcd disconnected. however with grinding and malfunctioning sounds.
i was not able to pass bleeding or adaptations after many attempts.
inpa gave me no indication of a pump failure. i also replaced all the spring detents and still no start. so now as i’m halfway through my own manual conversion, and stuck waiting for parts, i’m thinking about any other issues i may or hopefully may not have when i’m done
i’m hoping that i can finally drive the car again after being able to manually put it into gears.
