I have the shims...it’s fantastic. I recommend it for any track car.
Comprehensive Steering Information Thread
Thanks Volke! I was one of those guys on FBOriginally posted by Volke View Post
It does not. That's a myth due to the CSL having 10 mm wider track width up front. 6mm comes from the wheels being 3mm lower offset. The other 4mm is from the change in control arm angle at the lower ride height.
The CSL king pins either add 1 degree static negative camber without increasing SAI by 1 degree like you get using camber plates to make the same adjustment, or they decrease SAI while keeping static camber the same. Just depends how you align your car. Either way, the result is your car loses slightly less caster when you turn the wheels off center compared to a regular M3 with the same camber specs, and that means you gain a little less positive camber when the wheels are turned. I've heard it makes turn in feel a little better, but I cannot confirm.
I'll add more about the king pins and the effects on suspension geometry to the original posts when I get a chance. Promised some guys on FB I would do that too.
Might have more to do with the cars they're installed in stock-- e.g. the Z3 has a short wheelbase, so it likely does feel twitchier on the highway with the same rack.Originally posted by terra View PostI do find it funny that pretty much all of the rack upgrades ended up being 50mm/rev and linear. and in fact to date there's nothing confirmed to be faster. You'd always hear about people calling the 330 rack a modest upgrade which had a progressive feel while others would say the Z3 rack is so twitchy that it's hard to drive on the highway. Shows how much of our perception is susceptible to suggestion.
I did 2 shims/25% on both cars and have no regrets.... and my wife hasn't complainedOriginally posted by dl.m3 View PostWish I could read through the old m3f thread... Planning to do reduce my power steering pressure, how many shims is everyone doing? I have a ZHP rack and underdrive pulleys, I want heavier steering but don't want a workout while parking my car. Suggestions?
I meant those were the sort of statements in the context of retrofits into e36 M3s and such.Originally posted by Obioban View Post
I perhaps should have inquired before I had mine installed, but is there any *disadvantage* to this?Originally posted by Volke View PostThe CSL king pins either add 1 degree static negative camber without increasing SAI by 1 degree like you get using camber plates to make the same adjustment, or they decrease SAI while keeping static camber the same. Just depends how you align your car. Either way, the result is your car loses slightly less caster when you turn the wheels off center compared to a regular M3 with the same camber specs, and that means you gain a little less positive camber when the wheels are turned. I've heard it makes turn in feel a little better, but I cannot confirm.
There's no reason you can't do both. The pulley doesn't affect the steering weight. The smaller pulley just makes it more likely you will momentarily have zero assist if you try to turn the wheel too fast at too low engine RPM due to voiding in the steering rack from the pump not being able to output enough flow.Originally posted by Pace View PostHas anyone used shims along with a smaller diameter power steering pulley?
Nothing you need to worry about. It changes the scrub radius a tiny bit, and less SAI also reduces the centering force that makes the wheels seek the straight ahead position. You can always add a little caster with plates to make up for this if you notice the reduction and don't like it.Originally posted by terra View PostI perhaps should have inquired before I had mine installed, but is there any *disadvantage* to this?Last edited by Volke; 05-01-2020, 10:48 AM.
Yes, the black plastic on the spline can be removed, but years of dirt may make it hard to do so. Just go slow and use some WD40 to avoid breaking it.Originally posted by rbg View PostGuys do you know if that alignment plastic cover can be removed from our racks?
Sorry, for the slow response, I only check here when I get a PM.
I forgot to post an update but I used 4 shims for 50% reduction and I love it! I do notice that at stop or in a parking lot, more force is required to turn the wheel but nothing crazy. I drove my friend's NSX with no PS and that was a nightmare compared to mine lol.
This is the perfect solution to the overly light steering from the factory. Thanks Volke for making this DIY and selling those shims!
Thanks for putting together it is good to have all this info in one place again! I have an 01 which has an MK20 ABS module (which is the abs in the earlier modules). I have seen on the M3 cutters that there have been some work arounds with changing parameters but the reviews have been mixed some people say you should stay away (if you have MK20 specifically) and some say you should do it. I know build journal has an update for the MK20 module which converts it to something similar to an "MK 60 M Track Mode". I was going to rebuild/replace or change out the steering rack anyways because there is play right now in mine.
1. I wanted to bring this up for anyone that needs to factor this in since it is comprehensive steering thread and I had not factored the difference between MK20 and MK60 ABS Modules.
2. I didn't know if there was anyone that has a work around for this if it becomes a problem during normal driving (other than turning DSC off)?
