M3 Wheel Fitment
    M3 Wheel Fitment
    So I’m sure this topic has been discussed previously, but was hoping for some insight. I recently picked up an e46 and have a set of wheels I ran on my e90 m3 that I was wondering if they would fit on the e46..
    19x10 et 27
    19x11 et 31
    Any input would be appreciated and also if anyone knows what size tires would be best that’d be great too.
    Suspension is Koni ground control I believe dropped about an inch.
    Thanks
    If you have both why not try them? I suspect the fronts will poke a bit though.
    Regards
      I am not an expert, but I think you could make the fronts work with a quite a bit of negative camber.
      The rears to me seems like they would fit inside the arches (perhaps if the lip is cut/rolled).
      But the inside of those rear wheels will poke out like 23mm more than stock wheels would, not sure if that clearance is there.
        That's a very aggressive setup and will take a bunch of work to make it fit.
        2004 Dinan S3-R M3
        2023 X3M Competition
          Appreciate the input everyone. I’ll probably just end of selling them and getting a different set
