What trans fluid?
    What trans fluid?
    Tbonem3 Started the engine oil discussion. How about trans fluid? What are you running?
    P.S. I just ordered MTF-LT-2 from FCP which was branded Pentosin on the website, but I got sent BMW Group MTF-LT-2. Manufacture date on the bottle reads 25.06.2019.
    ‘02 TiAg/Impulse Slicktop
    Elf HTX 725 75W-80
    MVP Track Time
      Lucky you op!
      I use pentosin mtf2 (oem bmw spec 75w80 gl4) in e46 m3 getrag and lubromoly mtf 75w gl4 in 6speed zf 128i.
        At what interval is everyone doing it, 30k, 50k, etc?
        I have Pentosin mtf lt2 GL4 in at the moment.
          LOL wat. Lucky you. Kinda effed that they're charging $43/liter tho :/ this ain't no gold nanoparticle FM boosted diff fluid caman
          I'm also running BMW MTF-LT2 75W80. Bought 10 liters of it from Kaiv for $120 a year or two ago, so it should probably last the life of the trans at this point
            Experimented with different brands quite a bit so really short intervals personally, but I'd say 30-60k depending on several factors, for a street car. If it's barely driven, maybe there's a time frame rather than mileage
            literally every thread needs to be clear if it's a race car or street too.
              The nice thing about using the obc for fluid change intervals is that it changes based on how hard the car is driven.
                My 2 cents, OP I am also running the same MTF-LT-2 Transmission Fluid (MFG part 83-22-2-339-219. I bought mine from ECS tuning.
                I replaced mine 2k miles ago and did it as part of the Inspection 2 maintenance list. Have had no issues so far. Driven as a street/ weekend car for all its life.
                  Only had MT90 as the time but so far trans is fine after a whopping 150 miles. Shifts are solid. I drive and SMG so I can't feel it through a shifter or clutch pedal sadly but it's ok. I worry less about my synchros with an SMG and more about the clutch itself.
