SMG code 114: Auswertung Waehlhebel (Evaluation selector lever)
    Hi,
    Anyone has experience with this error code? Attached full report from INPA.
    What is the "selector lever"? Is it the shift knob in the middle or could it be the paddle shifters? I just removed the trim around the shifter while doing an armrest delete, could it be related to wiring in the area?
    I find very odd that in occurrences 2 and 3, there are many zeros. Ambient temperature is at the minimal value and it seems like there is no data (all zeros and "undefined"s). What could be going on?
    Here is the translation by Google for convenience:
    Code:
    ERROR MEMORY REPORT
    Date: 11/03/22 18:37:25
    ECU: SMG2
    JobStatus: OKAY
    Variant: SMG2
    RESULT: 1 errors in error memory !
    114 Evaluation selector lever Error frequency: 1
    Error occurred 1. times at:
    Odometer reading 0.00 km
    Ambient temperature 13.00 degrees C
    Voltage supply Ubatt 13.80 V
    Selector lever signals 1.00 0/1
    Direction of travel 1.00 forward
    Selector lever position 4.00 selector lever in A (automatic)
    not relevant 0.00 -
    not relevant 463.00 -
    Desired gear 3.00 3rd gear
    not relevant 4.00 -
    Error occurred 2. times at:
    Ambient temperature -48.00 degrees C
    Voltage supply Ubatt 0.00 V
    Selector lever signals 0.00 0/1
    Travel direction 0.00 not defined
    Selector lever position 0.00 Selector lever position not defined
    not relevant 0.00 -
    not relevant 0.00 -
    Desired Gear 0.00 0/Neutral
    not relevant 0.00 -
    Error occurred 3 times at:
    not relevant 0.00 -
    not relevant 0.00 -
    not relevant 0.00 -
    SG specific
    sporadic error
    Have you had the trim around the shifter removed recently? If you remove that trim with the car on it will trigger this code.
    I would check the wiring going to the gear lever. And if all is fine you might need to pickup a new gear lever.
      Yes, I did remove the trim and drive the car without it. So that's my explanation, huh? Interesting, why would removing a trim piece trigger a code?
        Because the wiring that needs to be disconnected to remove the trim piece was disconnected and the car was running without those things plugged in.
        Connect everything back and clear the codes. See if they come back.
