Clicking Noise When Under Load?
    Hey everyone.
    I started the M3 up for a drive and began hearing a clicking noise coming from the engine when I give it gas. I had someone hold the fan while I turned the car on and again gave it some gas - sounds like it is coming from around/under beauty cover area.
    Some info:
    Rod bearings were replaced les than 20K miles ago
    I have Cat Cams 280/272 (correctly installed) with stock followers
    The noise is not present at idle/sitting still
    Going to have it towed to a shop but any preliminary thoughts here?
    My first thought when reading this: Have you dealt with your VANOS yet? Anything done there? That's the first place I would consider based on the description
    - Jonathan
    2004 M3 - Build thread
      Re VANOS:
      - Upgraded the exhaust hub (stronger unit with thicker tabs)
      - used stronger gear bolts
        Any aggressive driving recently (track use, banging on limiter, etc.)? What's your redline set to? Maybe the engine spit a shim.
        I would pull the valve cover and investigate.
