To Schrick or not to Schrick
    Originally posted by genesis View Post
    I would be paying someone to do the work, which leads me to my next question-what should I expect to pay in labor to install the nee cams and followers?
    Make sure to refresh the head gasket too while you're in there. S54 head gaskets inevitably go out.
    Instagram: @logicalconclusion
      Members of this board will have you rebuilding the engine, transmission, and diff if you follow their advice. Replace the worn parts with good used stuff and move on.
      2003.5 SG/Grey
        Warranty book time to replace the rocker arms is 17hrs, most shops will use a 1.5-2x multiplier of that number. BMW also calls for pulling the head to do that job, but it can be done in the car IIRC.
        thanks
          Agreed. It sort of depends which follower has gone bad, I think? If it’s at the back of the motor that’s a pretty ‘easy’ replacement as those are the ones that come out first when you pull the follower rod. But if it’a one of the front ones that’s gone bad… you might have to remove the front clip if the rod fouls against the radiator support.
