S54 Dyno Database
  • digger
    Originally posted by stash1 View Post
    Yep, think we’re on the same page. When I said the avg. stock M3 makes around 275-ish WHP...I was referring to SAE Dynojet numbers. What I’m still puzzled about though is the fact the Martyn’s projected 340-360 BHP number is about on par w/our DJ numbers w/similar mods...yet his stock base numbers seem way higher than our WHP numbers?
    it baselined at 281whp which is a bit higher than stock but its a euro car, has the eventuri which eliminates the bulk of the losses from the induction system and it has a aftermarket ECU so its a straight forward thing to tune fuel PW and timing, ignition timing, vanos etc.
    A stock M3 makes 285 ish on a DJ if its running right which would probably be slightly more than that if it was low mileage to so not much inconsistent there.
    The elephant in the room is cams and airbox netted like ~15-20 numbers maybe, its a bit hard to tell as the corrections are only applied to the flywheel numbers and the rotating mass changed from 50-70kg but that’s a lot less than what many would have you believe even accounting for the eventuri
  • digger
    Stash1,
    I use to live at that side of the pond I am not a fan of how European's do a dyno.
    Their dyno relays on crank or called flywheel hp.
    Whit another words, no one knows how much is the dyno calculating the drive train loses.
    Why I like Dyno-Jet at 14% drive train losses some consider 15% bit I am at 14%.
    Std E46M3 on dynojet puts down somewerw between 275rwhp to 280rwhp. Ones you have
    that % figured and then you ad parts you know the gains at the crank by calculating 14% One
    takes 333hp crank SAE and -14%-15% you come up to that number +/- with very small
    variations like weather temp, humidity, worn out engine etc are subject to this minimal variation.
    I have friend in EU Germany who tuned his E39M5 and per the dyno and tuner he pulls 460hp crank
    only from Tune. There is no S62 in existence that will produce 60hp at the crank gain from 400hp
    factory crank hp, from tune only !!!! period put on pump fuel.
    S62 with the best spoke tune will make ~25-30hp crank maaaaax. 415 SAE crank - 14%= around
    356rwhp. So 460hp DIN - 22% should match what a healthy tuned S62 will produce in US Dyno-Jet.
    Per our US calculation 460hp crank - 14% we should see 396rwhp dyno-jet something that will
    never ever happen from tune only. Perkins build S62 will be in that range of power.
    Dyno HP should be calculate coming from Factory numbers. Meaning if we take std E46M3 to
    a European Dyno we should see exact in the range 339-343hp crank....as how BMW AG
    advertised in EU E46M3 at the Geneva autoshow back in 1999.
    US dyno do fluctuate by tremendous amount and one will never see consistency as how we
    see her in US using Dyno-Jet.
    Regards,
    Anri
    It says 295 whp and 373 bhp and 78 hp losses as tested/uncorrected. the corrected "flyhweel" numbers are 375 hp / 273 lb-ft. which is fairly close to a CSL albeit the cams are little larger hence numbers are a almost 20bhp higher torque numbers similar
    Not sure the relevance of m5 example, there are s54 dynos flung about on these forums with more rwhp than flywheel estimates for the same mods so funny business on both sides.
    the Maha is fairly reputable dyno brand, they are in the US to but most operators dont seem to use the coast down feature in these jurisdictions
  • DESMDR3
    Very first dyno so no baseline. APE flex fuel kit, B-Spec tune, catless headers. Ethanol blend @ E53
  • Anri
    Stan,
    Read the Dyno with cams and box etc.
    Do the math and you will see how much the dyno calculation will never make sense to you.
    Rear wheel 294rwhp. Crank says 378 BHP (crank HP). So, 378-22%= 294rwhp.
    Hope this will make more sense to you ?
    Regards,
    Anri.
  • Anri
    Stash1,
    Absolutely on the same page, indeed here in US we are measuring SAE.
    I am very picky on dyno numbers and dyno settings. I hate cheating also
    I hate when a tuner will tune my car and set the dyno to show stupid low rwhp. It did
    happen ones...and will never happen again. DanM. tuned one M6 and the dyno
    showed 180rwhp on Mustang Dyno and after his tune the wheel showed 212rwhp.
    Hmm so std M6 is 227rwhp Dyno-Jet.....so sure he made gain of 32rwhp.
    My point is that. If the Dyno-Jet rollers are lubricated, the weather factor box is
    operating as it should, straps are not done for HP. Tire pressure is not at 70psi
    you get what I am saying right ?...proper set up.
    We can get a very darn close to what aaaalll tuners and these hi performance parts,
    cams, exhaust etc can show as of real gain over std car being at SAE 333 US spec.
    Another factor I have seen Dyno operators do is they perform passes in a
    low gear. What I mean is say we have 4.10 rear gear and 3rd gear ratio is 1.66 which is relatively
    short gear, when the operator start the pass at say 3000rpm the engine accelerates
    the roller fast and for very short time to rev limiter. Indeed S54s in NA form with cams or without
    will never ever spin wheels but but but the proper way is to put hi gear 5th and perform
    long pass, not short pass.
    Martyn is making gains for sure with his tune. Dyno is a measuring tool for performance parts
    nothing wrong with that, but personally I prefer the other way around.
    Stan, don't keep trying to find logic because it will never make sense to you. Again 333SAE Crank
    HP - 14-15% is around 275-280ish few here few there.
    As Martyn says S54 BHP in UK makes between 315-330BHP meaning crank hp so we are somewhere between
    13-33hp from what BMW AG rates the S54 at 343hp DIN crank for EU market so were is the logic ? so say
    we put (30) S54 cars on same dyno and most % shows 310-315 BHP crank average, were is the logic ?
    At last, most people think a Tuner is a Magician, they can do so much. I have been a witness
    of were tuner will spent good amount of time to squeeze every bit of the engine and were there
    is no more room the limits are met.
    Customer's response is "That's it ?!?! I was expecting more".......
    On S54 std engine when the US cats are moved towards the back so that the
    exhaust pressure is reduced and a good tuner tunes the engine and what ever gains are that is it.
    Beyond that point one must open the check book and the first number is $5000k and up for Box, Cams,
    rockers arms, re-tune etc. The snow ball rolls of the cliff....
    Regards,
    Anri
