How do you know when your motor mounts are bad? I’ve had the car for a few years and haven’t noticed any difference in NVH but I’m doing my rod bearings soon and I noticed a lot of people change out the motor mounts as well. I managed to take a picture of mine. Do these look bad? Should I just change them out?
2004 M3 Coupe - Imola/Black | AA Supercharged (432 whp / 275 ft/lbs) | ARP Head Studs | ACL | Besian | Mishimoto CC | AA Headers w/ 100 Cell Race Cats | SS Section 2 | OEM Section 3 | TCK DA 400/500 | TMS Rear Camber Arms | Apex Arc-8 18x9 / 18x10 | 996 Brembo (In-Progress)Tags: None
blip the throttle a little, does the engine rock quite a bit?
You can also just decide to change them out if they're old and/or have like 60k+DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Most of the time that I want to replace a part, even if it isnt showing tell-tale signs of needing replacement, I feel a nice improvement and my mind is at ease knowing I should be good for the next ____ miles.
Rubber degrades over time. I'm sure if you replace them you will feel an improvement.
Sometimes the fan is close to hitting the shroud or the front of the oil pan close to hitting the sway bar. Other than that whatever ^ everyone else said.06 ZCP SMG | HTE CSL MAP QuaranTune | SL CSL Airbox | Eventuri Scoop | DMG Strut Bar | RE El Diablo | CPI Euro200R | AP Headers | Porsche BBK | ST XTA | TMS 3-Pulleys/F-Sway/Mono FCAB | AKG Trans/diff/Subframe/RTAB | SPL RCA | SGT SCZA Trunk | ACL | Beisan | Redish | AFD E85 |
Budget CSL MAP Conversion
Thanks guys, I’ll probably just replace them. I don’t think they are bad so it’s more for peace of mind for the future.2004 M3 Coupe - Imola/Black | AA Supercharged (432 whp / 275 ft/lbs) | ARP Head Studs | ACL | Besian | Mishimoto CC | AA Headers w/ 100 Cell Race Cats | SS Section 2 | OEM Section 3 | TCK DA 400/500 | TMS Rear Camber Arms | Apex Arc-8 18x9 / 18x10 | 996 Brembo (In-Progress)
Originally posted by Robert's_BMW View PostI don’t think they are bad so it’s more for peace of mind for the future.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
If I saw those in a customers car, I would suggest them be replaced. The dry rotting will only get worse. BMW has good engine mounts, but why wait for the failure to come? Those are probably originals.This is my Unbuild Journal and why we need an oil thread
