Is there a Brake Master Cylinder Upgrade for Big Brake Kit?
    I have Stoptechs front and rear and the brake pedal is a little less firm early on which I'm fine with. Better than the on/off feel of the OE brakes but most people prefer the immediately stiff pedal.
    I have the 996 brakes and 100% agreed. Pedal has a little more travel than stock but combined with hard compound track pads it makes modulation much easier. For me it puts the pedal in just the right range for heel toe while threshold braking.
    I put the E65 MC in my E39 M5 though and that was a big improvement. Those brakes have way too much travel.
      How does a bigger master cylinder interact with the DSC system? My immediate thought is that it would throw some of the logic off for ABS/traction control thresholds.
        Larger MC yields less pressure for same pedal travel. I dont actually think that a larger MC will necessarily throw the ABS or DSC out of whack that much as the value in the brake system they care about measuring is brake pressure.
        From an ABS standpoint I think it would actually work just fine. But according to Lee at massive brakes the ABS may actually damage the pistons in the master cylinder if they arent designed to be used with ABS.
        DSC, I think the same thing applies - the brake pressure sensors will still measure the correct pressure going to each brake circuit.
        What I think mess up the ABS/DSC the most is brake bias being out of whack. So if you choose a master cylinder where the bias is much different than stock the ABS and DSC will be unhappy. Similar issues when installing BBKs to be honest.
        I dont have any direct experience with this so take it with a grain of salt.
          Yeah, actually what you're saying does make sense. The only factors the DSC has to work off are brake pressure, wheel speed and data from the DSC sensor. So was thinking that messing with the brake pressure might confuse it a bit. But I guess as long as you keep the brake bias consistent, you should be okay, as the torque at the wheels vs brake pressure curve should be the same as the stock one. The only thing that might change is the point along the pedal's travel at which that pressure is reached.
            Your problem can be solved by removing the rear F40 kit. It is a subpar kit and displaces too much fluid based on piston sizes and prob is not needed for performance on our cars. 345mm rear rotor?
            F50 and F40 are kits that actually came from respective Ferraris of the 90s. Even F40 owners complained about their brakes.
            Youtube DIYs and more
              Did you try the e65 master cylinder on your e46 m3? I am thinking about doing this. Wondering why there are three hardline ports on the e65 cylinder though ?
                Technically an e65 MC should help as it has a bigger bore. 27MM vs 25.4.
                Its a great upgrade in the e39 M5(also 25.4 bore size)
                It will take a bit of work to retrofit it tho since you have to relocate the pressure sensors.
                But there are OEM solution for that (using eg.34336760914 to relocate the pressure sensor)
                It's been a while. well, I couldn't bring my car to track for a while. I'm trying to prepare my car for track few months later.
                I couldn't solve it since I didn't dirve my car.
                Now I found this. pretty same situation that I have.
                Bimmerforums is the preferred online BMW Forum and community for BMW owners. At Bimmerforums, you will find technical how-to information maintenance specifics audio advice wheel and tire combinations and model specific details not found anywhere else. Our professionals are here to help make sure you find the answers you need to your questions and our community is here to help other brainstorm ideas for the future.
                from the thread OP, he put Porsche 997 carrera booster and 997 gt3 master, part # trw : pmn166.
                well, I was thinking put e65 master cylinder to my e46 m3. but the shape looks bit different. and My car is early model, so It has TRW.
                Since I have very basic and limited knowledge on this topic, I wanted to start a discussion where more knowledgeable members can chime in. We all know that E39 across the range has the same MC, from 520i to M5. I recall that my old 530i had better brake pedal feel than all 3 M5's that I've...
                both E39 and E65 master cylinder look same but only difference is the diameter of bore. 25.4mm vs 27mm. So the retrofit seems almost direct fit. but I couldn't find any of retrofit E65 MC to E46 m3.
                If there is example of E65 Master Cylinder on E46 I would like to go that path. but couldn't find it.
                other interesting thing is My car has TRW master cylinder Part # PML435 (25.4mm)
                997 gt3 MC part #TRW pmn166 (27mm)
                PML435
                pmn166
                They Look alike.
                maybe getting 997 brake booster and MC, retrofit to my car will be the best choice? or getting E65 MC ?
                Does anyone has the experience like this? please share some!
                thanks.
                  I found this thread but unfortunately it does not have any pictures, but sounds the GT3 can be adapted to our cars. Has anyone tried it?
                  I have never liked the feel of my brakes despite being bled over and over and having brembo calipers front and rear.
                    I have found that e9x M3 also has a MC that can potentially be an update, as is 26mm/22mm, slightly larger front piston. the issue is the orientation of the lines is on the inboard side.
