Faulty camshaft position sensor codes?
    What phone was this filmed with cause the audio quality is not very good? In that clip, the VANOS doesn't sound like it is making the right noises. Check the "After" part here for what it should sound like -
    iPhone 10, there was some wind noise too as it was filmed outside. It kind of sounds like after, but I’m not 100% sure. I’ll have to listen / film it again not that it’s in my garage.
      Originally posted by props View Post
      Beisan it is! Their prices are a lot more reasonable too. Good to hear that the oil wasn’t low, I was told to try and keep the oil right around full (not at the line or above it, but right under it,) and panicked when I saw it at half. It’s weird my SES light turned off after putting oil in. I figured low oil would trigger a CEL either.
      Low oil triggers a low oil light . Very low oil triggers a low oil pressure light.
      The markings on the dip stick mean what they say-- min is the minimum you want in the car, max is the most you want in the car, anything between min and max is just fine.
        Meant to say I figured low oil wouldn’t* trigger an SES light. And that’s good to know - relieves some stress on my part. Hoping the VANOS rebuild & valve adjustment fixes some of my current issues, during times like this I start to miss my E36 M3 aha.
