Originally posted by Slideways
Faulty camshaft position sensor codes?
Originally posted by props View Post
Beisan it is! Their prices are a lot more reasonable too. Good to hear that the oil wasn’t low, I was told to try and keep the oil right around full (not at the line or above it, but right under it,) and panicked when I saw it at half. It’s weird my SES light turned off after putting oil in. I figured low oil would trigger a CEL either.. Very low oil triggers a low oil pressure light.
The markings on the dip stick mean what they say-- min is the minimum you want in the car, max is the most you want in the car, anything between min and max is just fine.
Low oil triggers a low oil light. Very low oil triggers a low oil pressure light.
