Converting back to lug bolts from wheel studs
    Is there anything I should do other than clean and chase the hub threads?
    2005 ZCP SMG ///M3
    I’ve used thread chasers and the ones i’ve used don’t work to get the old threadlocker out. I had to resort to using a tap.
    You will need to heat those studs up a fair amount (60ish sec with MAPP torch),
    An old thread I wrote for when changing wheel studs:
    Some of you will file this DIY under the "duh" category. Pretty much anyone can install wheel studs right? There were some subtle issues with the install of these particular studs that I think warranted some insight. Here are the studs being installed (https://www.bimmerworld.com/Wheels-Tires/Studs-Lug
      Nice write up. Saved for later!
