Battery tender / trickle charger recommendations?
    Hey guys, what are your preferred methods of keeping the battery topped off on cars that aren’t driven that much? Not just e46s, I need to get probably two or even three of these so I would like to make sure to get good ones.
    '01 M3, Imola/black
    I like the CTEK, you can also get a cool little deal that with slight modification you can make a discrete quick disconnect.
    Find an online doctor for pink eye, sinus infections, acne treatment, and more. Visit Amazon Clinic when you want convenient care for common health concerns.
ID:	193939 Click image for larger version
      Had good luck with both ctek and noco.
        I've been using the same Ctek 7002 for the past 10 years. Use the rear bumper tow hook cover hole for the quick disconnect so no need to keep the trunk open. Lawn mower also has its own Ctek. Highly recommend.
        Mike
        02 M3 Titanium Silver / Black
        11 Tundra SuperWhite / Black
          Recommend CTEK
            OEM
            Sent from my Pixel 7 Pro using Tapatalk
              +1 for CTEK, I run on both regular and Li batteries (different charger).
              Youtube DIYs and more
                CTEK or NOCO. A friend just bought a few NOCO genius 5 for his 2 cars and he love them. NOCO is less expensive, too.
                  CTEK has a slick cigarette lighter attachment that works for trickle charging in the E46. I have both their lead acid and lithium charger variants, both are great.
                    I'm happy with the Noco Genius 5 I found brand new on offerup for less than retail.
                      I have two CTEKs. one is 6 years old and the other about 2.5. Zero issues.
                      2007 Imola Red Z4M Coupe
                        Noco Genius 10. Been rocking it for years. 10 amps so you can code with it and not worry about the battery.
                        Currently $75 on Amazon for Cyber Monday:
                          CTEK or NOCO. You cant go wrong with either.
                            Thanks guys, I went with the CTEK
                            '01 M3, Imola/black
                              CTEK ftw. All the OEMs use them for a reason
                              2003 E46 M3 TiAg/Cinnamon 6MT
                              2005 E46 330i ZHP Imola/Sand
                              Instagram:@thegenius46m
