turning crankshaft on SMG engine (valve cover opened)
    I'm in the process of putting vanos back on and it seems like my crank isn't turning easily after a couple of ratchet turns against the crank bolt. Is it because the car remains in gear? if so, Should I try turning the key to accessory and shifting to neutral?
    thanks
    nvm, i jacked up the rear and disenaged the ebreak. 馃ぃ
      Neutral
        i didnt want to turn on accessory in case it does something to offset vanos timing
          I wonder if there's a way to get into neutral mechanically like you can with the DCT.
          DD: /// 2011.5 Jerez/bamboo E90 M3 路 DCT 路 Slicktop 路 Instagram
          /// 2004 Silvergrey M3 路 Coupe 路 6spd 路 Slicktop 路 zero options
            Before working on the VANOS or adjust valve clearance, or anything that requires turning the crank, tranny should be in neutral to make life eaier.
              It won鈥檛. You set all the timing with alignment pins manually.
                Disconnect the electrical connector to VANOS and put it in neutral.
                Unnecessary though because the VANOS only works when there is oil pressure.
