Do they break easy during power launch? I had problem with my old e36 m3 before but not sure if e46 would do the same thing? If so, which part number would be? I want to avoid break it because it cost a lot of money to remove the broken bolt. lol
Diff bolt question
Diff bolt question
2003 BMW M3 6MT - Oxford Green with Cinnamon leather. Supersprint | Apex wheels | BC Coilovers | Status Racing seat | HTE Performance Tuning | Megan headers | SMG to 6MT swap | Reinforcement plates | AKG Short Shifter | Wisefab Angle Kit | DriftHQ Rear Diff Brace | Clutchmaster FX400 |Tags: None
Old rear diff bolts (etorx) were fully threaded and too weak so they were updated to be mostly solid shank with enough threads for fastening. Just look up the parts on fcp or ecs, drivetrain.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
There's updated parts for both front and rear bolts. Rears were updated to a design that fits more snugly in the bushing and thus reduces clunking. Front was updated because it tends to shear (I think).
Updated front: 33177840535
Updated rear: 23001222891
Saved this procedure from the old M3Forum for installing diff bolts:
Also be careful with the front bolt, I cross threaded my diff mount when doing mine.Insert front bolt
Insert rear bolts
Torque front bolt to 200 Nm
Torque rear bolts to 20 Nm + 90°
Edit: Seems like the front bolt was not updated. 33177840535 superceded 33172282077, but the design seems to be the same.Last edited by heinzboehmer; 05-02-2020, 12:28 AM.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Hmm I don't remember that front one being updated. Do you remember when?
Rears I thought were breaking but maybe it was just that the diameter was too small. Usually making that move is for strength, but could be fit. I remember changing them out, but can't remember the front.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Huh just looked it up and it looks like you're right. According to RealOEM front was superceded but the design seems to be the same. For some reason I thought the front had been updated to be half threaded like the rear. Updated my previous post.
Regardless, might make sense to source a half threaded bolt if worried about snapping that bolt.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
You can reuse the washers, just need the newer bolts.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
