Turner Motorsport CSL Airbox
  • gntrobo
    To those that were able to return their damaged item, how were you able to get the order number? Mine shipped with no invoice and was on the phone with their customer service for an hour. Thanks in advance.
  • jk715
    Seems like the original CSL design has a dip towards the rear of the box which would provide clearance for the cabin filter housing.
  • heinzboehmer
    Originally posted by rbg View Post
    Isn't the brace very close to OEM boxes as well?
    This is what the clearance looks like with my Karbonius box.
  • maupineda
    Yup, pretty sure they are, but I'm going to go through thoroughly and check everything and take photos before going to Turner with a big 'ol "hey, wtf >:["
    Assuming my install is proper, either: 1. everyone will experience these fitment issues (which, for the strut brace, seems possibly true so far as evidenced by the fatboys video) and haven't noticed because they haven't taken off the cabin filter after install yet, 2. my box is somehow out of spec, or, 3. I've somehow got some weird twisty frame damage that I haven't been aware of until now?
    The other option is to slightly bend the horseshoe bracket down, it is in cantilever and held by just one 13mm bolt, and the grommets to fasten the box to it would absorb some minor variation. I would try this rather than spacing the strut brace.
  • maupineda
    Yes, fully seated on the horseshoe bracket.
    In the video, it looks like their strut bar doesn't clear either and they had to use washers. But I worry that the washers would sacrifice the structural integrity of the bar.. am I overthinking that?
    The box rubbing on the cabin air filter housing is a much bigger concern, though. Left a pretty nasty blemish on mine, and I'm convinced that it would wear through the CF if I left it :/
    After your post, I searched for photos of the Evolve box, and even theirs seem to be a very tight fit, I wonder how the CSL design overcame that clearance, or does it have a different strut bar? I have Z4M, with the Karbonius box and I have plenty of clearance but is a different chassis.
  • rbg
  • jk715
    I thought I had the strut brace issue as well but after securing the bottom bracket while pushing down on the box, i have enough clearance (4mm) for the brace. In any case, i'll take mine apart as well.
  • ATB88
    Originally posted by jk715 View Post
    ATB88 Assuming the horseshoe bracket is seated all the way ( I had to push down on the box from the inside and screw down at the same time ), are your rubber seals around the dme properly seated?
  • jk715
  • r4dr
    Or call Turner tomorrow... seems like you shouldn't have to fuck around with hack solutions after spending $1500+ on their product.
  • COVID-19
    Just get a DMG strut bar. He’s currently working on this issue. Lol
  • rbg
    Look at the bright side -- it is bigger, so might flow better ;-)
    Take a picture would you? How much it needs to be lowered to clear?
    something like these with a proper length instead of original standoffs? https://www.amazon.com/Rubber-Absorb...NsaWNrPXRydWU=
  • ATB88
    In the video it looks like their strut bar doesn't clear either and they had to use washers. But I worry that the washers would sacrifice the structural integrity of the bar.. am I overthinking that?
  • maupineda
    ^ is it fully seated on the large horseshoe bracket under the box?
    Check this video out
  • ATB88
    Bad news: I'm getting some not so great fitment issues.
    1. I finally fitted an OE front strut bar that I picked up a few months ago. The bar very, very barely clears the unfiltered section of the box, but when driving things move/flex enough that they touch.
    2. Took my cabin filter tray out to find that it also has been touching the box at the back, and in my case, the vibration of the box against the tray has worn through the clear coat making a very large blemish.
    Has nobody else encountered these issues? Wondering if I've somehow installed the box incorrectly, but, I don't see how I could have. The throttle body boots are fully seated and the bottom of the box is mounted to the bracket underneath...
