At least in the USA?
why is E85 still in our petrol supply
What a threadDD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
The all powerful EPA makes rules based on biased information like every other government organization. Someone chokes on the good idea fairy and bam, they change something. 30 years ago, they swore we were heading into an ice age because of emissions. E85 at the pump is quite stupid but coincidentally is actually can make more power than gasoline. Look at how many cars can actually use it from the factory... Probably less than 1%. It's better for the environment thoughThis is my Unbuild Journal and why we need an oil thread
Corn lobby. Garbage.
Also garbage: corn syrup.
2008 Black/Black M5 Sedan
For sale: 6MT 2008 M5: https://nam3forum.com/forums/forum/c...fully-modified
Originally posted by Arith2 View PostE85 at the pump is quite stupid but coincidentally is actually can make more power than gasoline.
Originally posted by Jimbo's M View PostStupid? Why? Just about everyone here is always seeking more power, E85 makes that happen in a very noticeable way with this platform. What IS garbage is the E10 winter blend. Not only, it burns cooler, and living where you get well over fifty, one hundred degree days per year, 2500' elevation, a/c blasting away, with 100 octane, I never worry about it pulling timing. Just sayin'...This is my Unbuild Journal and why we need an oil thread
So many cars aren't designed for it and it'll wreak havoc on fuel systems. I just wish it was E85 and not E50-E80. That can also cause serious problems in an engine making pump E85 even more dumb. Thankfully companies like AFD recognized this idiocy and designed a sensor for it.
You contradict yourself about E50-E85 comment...you say it's dumb, yet you acknowledge that the kit auto adapts, which it does. You can run straight gasoline or straight E85, and everything in between. I've run E50, works like a charm. Personally, I prefer around E60 to achieve around 100 octane, and that's what I mix for.
Like I've said before, I've been on ~E60 for 15 months now with no issues whatsoever, and this is my only car. And if E85 goes away, I can go straight back to gas and not skip a beat other than losing considerable power.
Originally posted by Ruley View PostYou get more power, but not with the same amount. You have to dump more fuel to achieve the same bang. Not to mention it dries out seals and absorbs moisture.
Originally posted by Jimbo's M View PostHence why it's a kit. It's not just the "ECU" portion, it comes with fuel lines and the such.
Like I've said before, I've been on ~E60 for 15 months now with no issues whatsoever, and this is my only car. And if E85 goes away, I can go straight back to gas and not skip a beat other than losing considerable power.This is my Unbuild Journal and why we need an oil thread
Originally posted by Arith2 View PostEthanol is not good for fuel systems not designed for it, which are most including ours.
All the flex fuel solutions on the market for this car I know if are piggybacks... hacks I wouldn’t run. Long term they always cause issues (beyond the issues ethanol itself can cause).
Ethanol also clogs carburetors, making it terrible for all lawn equipment. it’s also terrible any time you park a car/anything for an extended period.
Originally posted by Obioban View PostAll the flex fuel solutions on the market for this car I know if are piggybacks... hacks I wouldn’t run. Long term they always cause issues (beyond the issues ethanol itself can cause).
