Hello boys, I have a question after doing research I'm coming up blank.
At night when you turn your lights on, your interior lighting including your dash should be a bright orange, for some reason mine remains dim. There's been a few times where I'm parked under flood lights, I turn on the car, turn the lights on and then it magically becomes bright. I've tried shining a light at the LCM module which works sometimes to trigger the lights to come on.
I'm assuming the little pinhole on the LCM module controls the interior lights, while the little pinhole on the HK SatNav only brightens up the SatNav correct? This is what I've gathered from research, does this mean my LCM unit is busted?
