Before I start pulling the rubber boot out of my interior, then struggling to get it back in place, I thought I’d ask here first..
Background: The OEM shifter is a bit rubbery, as most I’m sure are aware. If you pull your leather shift boot up and grab the base of your shifter, so that your thumb or finger is on the thin metal shaft under the thick shaft, then wiggle your shifter, you’ll feel pretty significant motion between the two major parts of the lever. Most of that rubbery feeling comes from the motion at that joint, as far as I can tell.
Solution: I like the damped feel of some rubber, and the autosolutions setups are just a bit too ‘direct’ for me, so I thought I might be able to make the stock shifter feel firmer with a simple mod. But I need one dimension before I can do that.
The ask: Can I get some help to measure this diameter? It appears to be about 10mm, but an actual measurement is what I need.
I’m trying to make a clamp that locks both parts of the shifter together:
