Radiator Recommendation
    What radiator would you recommend for a direct fitment (does not require custom mounting brackets or hoses) for use on a daily driven car that gets tracked occasionally?
    Looking for something that would be a cooling upgrade and reliability upgrade (no plastic).
    I see Mishimoto, CSF, ECS tuning, and others.
    Any input or personal experiences on success stories or units to avoid will be greatly appreciated.
    Thank
    Stock Modine. There are no "plastic" issues on our car like e36. Run less coolant in your mix for better cooling.
      Another vote for new stock, though I’d stick with 50:50
        Good to know, The PO of my car (intelligent man, BMW guy, knows what he is doing) had a shop do some work and seemed to think they installed some random radiator they had sitting around. It sounds really dodgy, and im not sure if this is true or not, but I will try to find a part number tonight to confirm what it is for my own sanity. Modine is good stuff. My AC condenser is so badly oxidized that im sure the lines will burst upon the first rogue pebble that makes its way through the grille at speed, so I will be "in there anyways"
          If you're in that harsh/cold of a climate, maybe do stick with 50/50 coolant.
            Koyo here, no complaints.
              Mishimoto. Deleted my puller fan, just have the pusher, no overheating on track or in traffic, even with A/C on. Will be deleting pusher and installing a electric puller since I have on laying around.
                I’ve been running Koyo for a few years with no mechanical fan, just the aux fan. No issues and it fit perfect. Really nice piece and likely the last rad i’ll ever buy for it.
                  New OE from FCP. Plenty of cooling capability with the stock system, so no need for a fatter aftermarket part.
                    When my sled’s odo hit 100k miles, I had the entire cooling system replaced, with “Genuine BMW Parts” from ECS. After that, my car ran cooler than when I first took delivery of it. Since then, I had Active Autowerk’s heavy duty fan clutch installed at around 150k miles (to replace the 2nd fan clutch along with another new genuine BMW fan blade just as a precautionary measure), and it all works great.
                      +1 for stock from me. 182k miles, quite a bit of tracking down here in Georgia in the summer. Not had much problems with heat. May refresh just because since she's getting old!
                      '02 E46 M3 - The high mileage street car
                      '05 E46 m3 - The neglected race car
                      YouTube & Instagram for track stuff!
                        From an online magazine called Moto IQ, they some years back, installed a Koyo radiator in their E46M. They produced a good write-up with many pictures. The web address to original article and the article itself is below.
                        Project M3: Part 16 – Koyorad All Aluminum Radiator Installation Cool Runnings by Pablo Mazlumian When it comes to our Project M3, most of its upgrades could be labeled as…
ID:	21879 Click image for larger version
ID:	21880 Click image for larger version
ID:	21881 Click image for larger version
ID:	21882 Click image for larger version
ID:	21883 Click image for larger version
ID:	21884 Click image for larger version
ID:	21885 Click image for larger version
ID:	21886 Click image for larger version
ID:	21887 Click image for larger version
ID:	21888 Click image for larger version
ID:	21889 Click image for larger version
ID:	21890 Click image for larger version
ID:	21891 Click image for larger version
ID:	21892 Click image for larger version
ID:	21893 Click image for larger version
ID:	21894 Click image for larger version
ID:	21895 Click image for larger version
ID:	21896 Click image for larger version
ID:	21897 Click image for larger version
ID:	21898 Click image for larger version
ID:	21899 Click image for larger version
ID:	21900 Click image for larger version
ID:	21901 Click image for larger version
ID:	21902 Click image for larger version
ID:	21903 Click image for larger version
ID:	21904 Click image for larger version
ID:	21905 Click image for larger version
ID:	21906 Click image for larger version
ID:	21907 Click image for larger version
ID:	21908 Click image for larger version
ID:	21909 Click image for larger version
ID:	21911 Click image for larger version
ID:	21912 Click image for larger version
ID:	21913 Click image for larger version
ID:	21914 Click image for larger version
ID:	21915 Click image for larger version
ID:	21916 Click image for larger version
ID:	21917 Click image for larger version
ID:	21918 Click image for larger version
ID:	21919 Click image for larger version
ID:	21920 Click image for larger version
ID:	21921 Click image for larger version
ID:	21922 Click image for larger version
                          Do we still think the gold standard is Zionsville?
                            Zionsville is the only one I would consider putting on my car other than OE(M).
                            (and only if I was having overheating issues-- as it is heavier than stock, and on the nose of the car)
                              OE or Zionsville.. Thats all.
                              Instagram: @_Frank_Stone_
