Is there a technique to get this C Clip back on? Rear qtr window
    Is it just brute strength? A tool or technique I'm missing?
    This is the hardware I am replacing.
    https://www.ecstuning.com/b-genuine-...r/51377020619/
    The diameter of the plastic piece is wider than the opening of the clip. I'm assuming that's by design since that's what locks in in place, but I can't get the damn thing on lol.
    It's hard. You need a tool to squeeze it on imo. I used pliers.
      Man, it is hard. The clip wouldn't budge using a flathead and a hammer. I'll try with a pair of pliers, the window is still on the car and it's difficult to get an angle. I'm afraid of snapping the plastic again hah.
        Ya that's why I suggested (and what worked for me) to squeeze, because you can get a lot of levarge and power as long as you have some decent forearms
        Striking it seemed too dangerous to me.
        Taking the window off is really easy, though removing the B pillar to get to the window is hard, as that requires removing the panel, which requires removing the seat bench (if you want to do it correctly and not lose/break a plastic clip).
          Hammering can break the plastic piece or the glass. Use flat nose pliers which squeeze the c-clip but places no pushing force to break the plastic piece. Open the window wide after disconnect the motor's ball joint.
