Karbonius at 140k?
  • Nate047
    Hardest thing is to remove the boot clamps. But if you get aftermarket ones it makes it easier.
    HAHA dude.. I feel this. I had to replace the intake cam position sensor not too long ago. So the IM has to come off, and those fucking clamps ruined my life for like... Way longer than I'd like to admit.
    What's the hot ticket for aftermarket replacements?
  • COVID-19
    Originally posted by bjz! View Post
    lol fitment problems? Streamline... go to karbonius, he already solved all the fitments problems, haha i can tell you because i've done all the karbonius airboxs generations... first ones... were a PITA.
    Yup can’t go wrong with Karb. I haven’t received my snorkel so I can’t comment on fitment issues.
  • bjz!
    There’s a few thread and videos out there.
    here is one https://youtu.be/Lj62HjYMJHc
  • Cubieman
    One minor downside to not running the "aux." (rear hole) hoses is that I am getting this weird kind of hissing noise at certain throttle input levels. It may be something else though, doesn't sound bad, just a different sound I am getting used to.
    The flap may play a role in this sound but I'm pretty sure if I got any sort of tubing longer than 6" this noise would go away. Probably a venturi type effect.
  • terra
    First and foremost, its a throttle. The effort was not spent on simply noise control.
    If they had to meet noise regulations to legally sell the car in some countries, then they would spend the time and effort.
  • Obioban
    Every dyno I’ve ever seen show it making less power with the flap closed than open— so, if it’s a throttle, I’m not sure what its function is.
  • jbfrancis3
    Fabspeed?
    Right! Thank you
  • heinzboehmer
    I don't have the flap and the volume depends greatly on throttle input.
  • jbfrancis3
    Acts as a muffler for the intake. There's a small opening in the bottom of the airbox that allows enough air to go into the engine with the flap closed at low rpm. The flap then opens to allow full airflow through the main opening (which makes more noise) at higher rpm.
  • Cubieman
    Fabspeed?
  • jbfrancis3
    Originally posted by sina View Post
    If I recall correctly last time someone ran the math on (SSV1 catless section + cats of equal quality + labor) the conclusion was that the savings would be insignificant (ie. at beast a couple hundred dollars) compared to having the guaranteed fit and finish straight from SS?
    That was me and I absolutely recommend buying the Section 1 directly from SS. I did not have labor cost in the equation, plus I chopped off the flanges and welded in v-bands, the point being I was already cutting things up. But generally speaking, its a no-brainer to buy straight from SS.
    Perhaps more importantly, and this is addressed with buying the SS section 1 catted (SS uses HJS cats), is you install good quality cats.
    A company has a write-up on why use HJS cats. Its starts with an F and they make exhaust components for this vehicle....completely blanking on the name.
  • Cubieman
    I am interested as well as I have the flap, but it isn't wired yet. I noticed at idle there really isn't much of a difference at all. In fact I don't really even hear the CSL airbox until just under 4k with 4.10 gearing.
  • sdmcoupe
    So the only difference is w/o the flap, the induction volume is a bit (or a lot) louder at lower rpm's than one with the flap?
  • heinzboehmer
    Originally posted by sdmcoupe View Post
    What exactly is the purpose of the flap?
  • sdmcoupe
