First symptoms were when coming to a stop in second gear, about 5mph, the car would shake while I was lightly applying the brake while coasting. This was only at a really low speed, usually right before the car automatically switches to first. When idle, the car would take super long to shift into R (from N) and 1 (from N), about 3-4 flashes of gear before it finally engages. When the car was operating normally, usually there was always a little clunk sound when switching to 1 or R, and the gear indicator would only flash once or twice. This time, the clunk was much louder and more pronounced.
A couple days later, SMG COG. The car wouldn't engage 1st gear, instead, started in second gear. The car was drivable, and would not throw me into neutral or out of gear. When switching into reverse, the car feels like it is literally slamming into gear. It's loud, it's almost like an S6 shift but you're idle and you're just going into reverse.
I brought it to a shop and got the codes read, I was told it was low pressure. I was recommended the Burkhart SMG motor repair kit. Went ahead and did that, got everything bled, etc...
After the Burkhart replacement, the SMG pump now primes for 6 seconds instead of 9-10. The car now engages first gear, and doesn't make a loud clunk, it sounds pretty much normal. However, when the car is cold, occasionally, it will still slam in reverse. No hesitations when switching to first. When the car is warm, it doesn't hesitate or slam into reverse, it only happens sometimes. I haven't tried too many times, I'm just worried I could do more damage. Also, when almost completely stopped in first gear, it feels like the car wants to move forward at times. It literally feels as if I'm touching the gas pedal very lightly, you can feel the clutch engage but I'm not even touching any pedal. I was out for a drive and while sitting at a stoplight, I had my foot off the brake. When I tried to accelerate, the car literally revved up and didn't move at all. This does not happen when I have my foot on the brake before I accelerate.
I'm just curious if anybody else has had these issues before. I haven't driven the car much since I got it back, I cringe at the thought of the thing slamming into gear like that. At this point, I might just bring it to the dealer. Any ideas would be appreciated, I'm just reallllly hoping it's not the pump.
