I tried searching but didn’t find anything relevant.
Are there any tricks or suggested ways to remove the 21mm bolt from the top of the subframe securing the control arm? I can just barely get a box wrench on the bolt, but I think it’s just spinning. I don’t really see how to make enough space to get the 6mm Allen wrench on the bolt and a 21mm wrench on the nut to get it loose.
Do I need to remove the sway bar to make more space?
it’s very tight in there. Any suggestions? Thanks!
This is on a ‘02 M3 if it matters.
