What rotors have you had better luck with, StopTech or Zimmermann for a stock replacement.
Which to Pick: StopTech Vs. Zimmermann Stock Rotors
How do you use the car and why asking about luck, in terms of what?
Youtube DIYs and more
- Likes 2
Vibration could be from pad deposits - once warm, slam on your brakes from time to time to "clean" them and leave behind a fresh pad transfer.
While I don't hold either of these companies in high regard, I don't see any issue using their blank discs for basic driving. I've used centric blanks for years as well as Meyle.
Like Gizmo said, it can come down to driving style/needs. I think it also can come down to whether you're ok with a chinese made rotor or not, and your budget.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
BMW does some of the work itself in Berlin. But ATE and Bosch also delivered to productionOriginally posted by dog2bert View PostWho makes the BMW rotor? FCPEuro doesn't indicate an OEM source
But I can say the same about them, there are even more OEM manufacturersLast edited by Andy2424; 05-03-2023, 12:51 PM.
I recently installed Zimmerman and had pulsing after like 2000 miles or something. It would be especially bad on hard braking. I exchanged them through FCP and the new set so far is perfect.
When I removed the old set, I noticed a ton of the zinc coating had built up underneath the rotor between the rotor and hub, and had scrubbed off. It created sort of a lubrication between those surfaces. I recall when I torqued that wheel it felt "mushy" as the nuts reached torque. So I think that was potentially a contributor. The rotors themselves looked perfect on the brake pad surface.
There's an old Italian saying which translates into "savings never leads to profit".
Should be a sticky on this forum.2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
