What rotors have you had better luck with, StopTech or Zimmermann for a stock replacement.
Which to Pick: StopTech Vs. Zimmermann Stock Rotors
How do you use the car and why asking about luck, in terms of what?
Youtube DIYs and more
Vibration could be from pad deposits - once warm, slam on your brakes from time to time to "clean" them and leave behind a fresh pad transfer.
While I don't hold either of these companies in high regard, I don't see any issue using their blank discs for basic driving. I've used centric blanks for years as well as Meyle.
Like Gizmo said, it can come down to driving style/needs. I think it also can come down to whether you're ok with a chinese made rotor or not, and your budget.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by dog2bert View PostWho makes the BMW rotor? FCPEuro doesn't indicate an OEM source
But I can say the same about them, there are even more OEM manufacturersLast edited by Andy2424; 05-03-2023, 12:51 PM.
I recently installed Zimmerman and had pulsing after like 2000 miles or something. It would be especially bad on hard braking. I exchanged them through FCP and the new set so far is perfect.
When I removed the old set, I noticed a ton of the zinc coating had built up underneath the rotor between the rotor and hub, and had scrubbed off. It created sort of a lubrication between those surfaces. I recall when I torqued that wheel it felt "mushy" as the nuts reached torque. So I think that was potentially a contributor. The rotors themselves looked perfect on the brake pad surface.
There's an old Italian saying which translates into "savings never leads to profit".
Should be a sticky on this forum.2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
