Cylinder leakdown higher after engine rebuild?
  • eacmen
    Did you reach out to Lang?
  • Chanman1029
    Crosshatching from the machining process.
    Cool, I atleast know what that looks like haha.
    Will get back here in a few hours and post my findings
  • Slideways
    Originally posted by Chanman1029 View Post
    yes! I’m actually about to pick up a bore scope rental from autozone as soon as I’m done with dinner, hopefully it will be good enough quality to see. What kinds of things should I look for? Tbh I’m not sure what “normal” cylinder wall wear looks like. Obviously a score would be very clear of something wrong, but what else should I look for?
  • Chanman1029
    Are you able to bore scope the cylinders? That way you can get an idea of how everything looks. Hopefully the crosshatching is still there from the machining; otherwise, you're looking for glazing or scoring.
  • Slideways
  • Chanman1029
    started a topic Cylinder leakdown higher after engine rebuild?
    Hey all,
    some of you may remember my post regarding my oil light coming on after reaching operating temp, however when I would check the oil level after shutdown, it was only slightly below the max mark once all oil drained back to the pan. During my investigations, I saw a noticeable amount of metallic material in the oil filter housing, so I thought maybe the oil filter was getting a little over worked, so even though only at 1300 miles on the oil, I decided to change the oil.
    Quick back story: this engine was fully rebuilt just under 3k miles ago, New main and rod bearing, CP pistons w/ rings, all machine work done by lang racing. First oil interval was 1200 miles with 15w-50 conventional break in oil, then 1300 on 10w-60, that oil last 1300 run was the oil I had just drained in the above statement.
    Ok, so the reason I rebuilt the motor was due to oil consumption. After doing a leakdown test prior to the rebuild my results were
    Cylinder 1: 3% heard at oil cap
    Cylinder 2: 4% heard at oil cap
    Cylinder 3: 2% heard at oil cap
    Cylinder 4: 2% heard at oil cap
    Cylinder 5: 3.5% heard at oil cap
    Cylinder 6: 3.5% heard at oil cap
    I figured this wasn’t really abnormal and concluded the consumption must have been from valve seals. Had the motor rebuilt, and here we are back at the current situation. When I saw all the metallic material in the OFH, I decided to drain it and take an oil sample like i always do. The report came back stating,
    “The oil filter clogging can be a reason for the low oil light, but we wouldn't rule out oil
    consumption due to a cylinder-area issue. Chrome (piston rings) and iron (cylinders and other steel parts)
    nearly doubled after a similar run as last time. Increasing oil consumption is a common symptom of a
    ring/cylinder-area issue. Ticking can be another. You might consider a compression or leak down test due
    to the wear. The other wear metals look okay, overall, but now aluminum (pistons) is reading at its highest
    level”
    I did a leakdown test yesterday, and my results were all consistently higher than before:
    Cylinder 1: 4%
    Cylinder 2: 5%
    Cylinder 3: 6%
    Cylinder 4: 5%
    Cylinder 5: 5%
    Cylinder 6: 5% All cylinders heard at oil cap.
    My question: How long do piston rings take to seat? Do you think those materials in the oil are normal for a new motor with less than 3k miles? Or do you think I actually have a ring issue, in which case I’m screwed, bc as good as everyone says he is, I highly doubt lang will stand behind any of their work as their website states zero warranty on any work they do.
