Does anyone have a measurement of the distance from their rear top and bottom shock mount points with the sway disconnected? I need a rough idea of how much droop their is.
Rear Control Arm Droop
I don't also might want to note what bushings are in the RTABs, I found B/Js allow a decent amount more droop than bushings (and limiters).'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Email to [email protected]
I guess along those lines IIRC mine with B/Js will bottom out with the LCA contacting the subframeOriginally posted by Cronenberged View Post
Thanks George, yea mine have the AKG 95A poly, but I do plan to swap those for B/J.'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Thank you gents.
cobra were you measuring with or without your clevis?
fattycharged do you have the carrier removed and upper control arm removed as well?Last edited by Cronenberged; 06-25-2023, 09:25 PM.
No clevis. To the sheet metal of the chassis.Originally posted by Cronenberged View PostThank you gents.
fattycharged do you the carrier removed and upper control arm removed as well?
carrier and uca's still in placeOriginally posted by Cronenberged View PostThank you gents.
