Hey All!
I am using an ACT 601010 Forged Flywheel and ACT B014 pressure plate on my S54. I am moving from the 420G transmission to a ZF320. I intended to use an E34 M5 clutch, but upon installation I found that it was slightly too thick to place with the springs facing the flywheel and there only appeared to be about ~5mm of clearance to the pressure plate fingers with the springs facing the transmission. Thus, I am guessing it would contact when disengaging.
Looking for suggestions here. I am guessing an E36 M3 unsprung clutch would fit fine as that appears to be considerably thinner.
Thanks in advance!
Thanks in advance!
