I need your help...
Story time.
Past: Cog light has been on for 3 weeks at this point (please don't flame me, be gentle) but no shifting issues or any symptoms of a malfunctioning smg. I thought heat related and kept dailying the car. When arriving home from work, car off, I heard the smg reservoir priming over and over again. Opened the res tank and saw it was low, and the sound (I thought) was the pump trying to suck fluid while being dry so I topped it off, checked for leaks, saw none and replaced the salmon relay (read somewhere to do that). So the priming sound / issue went away for 2 weeks.
Present: Woke up to dead battery after a long weekend not driving the car. When I hooked up the cable to jump the first this I hear is the priming sound. So it killed the battery apparently. I unplug the salmon relay and plug it back it and the priming sound stops, get the car jumped and drives fine. Thinking the res maybe low again I open the tank and its BRIMMED to the top with fluid. All the way to the rim. Uh huh? There is also fluid all around the cap on the outside so I think it's been leaking from the cap since it now has too much fluid. I stopped driving the car daily and took the relay out the keep the battery from dying just in case it goes prime mode again. Even though it hasn't acted up since.
What is going on here? Could it be solved with a simple bleed of the system? I did replace my starter recently (within 6 months) so maybe during that install air go into the system (removal of the reservoir is required for starter install)? Are these symptoms associated with the smg pump leaking internally (good god please no)? Any help or insight into this is greatly appreciated. To scared to drive the car now for fear of causing more damage but not afraid to fix stuff if I know what it is I'm taking apart and why.
Thanks in advance.
TLDR: Cog light, Pump/reservoir priming continuously while car is off, salmon relay unplug & plug back in temporarily stops priming, smg hydraulic fluid levels in res low one day to high another day. (obligatory "time to manny swap" comment)
Story time.
Thanks in advance.
