Saving a S54 From Parting Out.
    digger,
    You mentioned few days ago Competition Valve seat work.
    I am working on this S38 head and had a local very famous
    Machine shop working only Honda Hi performance cylinder
    heads...also S54 !!! and also on new Supras....
    The guy purchased Newen CNC machine for cutting only valve
    seats. I have to admit I sow the process and it gets the job done
    so fast! What this Newen machine did for about 5 hours it was going
    to take me a week of work..and thus why I decided to save time
    also from cost stand point I wanted to save money to my customer.
    So the idea is to bring the valve to throat in 90-91%. The original
    is in 89%
    Ones the head was completed I shipped to my shop and few
    weeks later now its the time complete the rest like cutting the
    valves etc...
    I decided to check the Concentricity as I always do if I use any
    services which I am not involved. Naive me I had zero doubts...this
    is done on CNC....
    Man when I checked the concentricity I could not believe my
    eyes..on all 24 seats I was between 6-8-thousand inch off.........
    I am very disappointed from Newen machine.
    From now on Competition seat work will be done In-House
    by me, it will take me up tp 2 weeks to do it but it will be done properly!
    Link
    Newen https://www.instagram.com/p/CvuktvjAPkt/
    Corrected by me here https://www.instagram.com/p/Cvum59hAfV3/
    www.euroclassicmotors.com
      digger,
      is in 89%
      valves etc...
      is done on CNC....
      Link
      I am not sure i did mention anything recently?
      In any case they obviously screwed it up. it wont be the norm to be that far out so i wouldn't blame the machine.
      Did you call them and tell them?
        Digger,
        When I left those heads I mentioend I want to see
        under .1 thou run out while I was after to pass
        90%+. Then right before I hopped in my daily driver E28M5
        I said please don't forget. A month later I started to work
        on the heads and seats are 8 thou off I called him up and he
        never picked up the phone he knows why I am calling back..
        Remember he is not cutting it by hand it's automated.
        Like I mentioned I see the problem with the Newen set up.
        I use the multi angle blade in one and I get to chose the specs
        I want. I also have my own technic..today I just finished 1 head
        which it took me 3 days...its slow but death accurate!
        Regards,
        Anri
          Digger,
          under .1 thou run out while I was demanding to pass
          Regards,
          Anri
          The following are based on my understanding of the Newen. the valve guide size changes depending on the head being worked. the operator needs to choose the correct "pilot" so you cant rely on muppets to operate and expect good outcome so not really automatic. i do think there are some fundamental flaws in the machine spinning pilot in the guide i dont like, but i could do better than 8 thou with a Neway hand cutter lol so they wouldn't be still selling machines of 6 to 8 though was the norm
            Digger,
            I found a quick short video. As we can see the design even with the right pilot
            how it works can allow some variations vs the traditional pilot which is rock solid
            ones installed in the valve guide deep and it locks. The head unit I am
            using goes very tight over the pilot !!! It's a bit of a process. The multi angles
            build in single cutter is made from very hard material, it is very important to get the
            cutting speed right because otherwise chattering occurs.
            To get perfect concentricity the cutting blade while its making the pass can't not
            leave the surface during cut via "corkscrew" motion.
            Concentiry is extremity important for the valve to sit properly and not lean on
            the guide inside...7-8 thou is a lot. Also banging the valve seat with more
            pressure from one side more than other for sure contributes for either drop
            seat or drop valve head.
            Anyway I am not looking back...
            Regards,
            Anri
              Digger,
              This is exact what talking about. My phone camera is full and I can't make
              videos more than 2min or less otherwise I would have made same video
              to show the process..I need go-pro type and then I can show the process
              which identical as the one seen in the video.
              These are LS AFR 300, please zoom in and you can see they are CNCd and
              also pay attention to how the seat is cut! Its done with Newen type of a
              machine which one can recognize by the pass (at least I can).
              Look at run out is same around ~8-9 thou absolute disaster.
              The machinist brought the concentricity to about 2 thou, I bring them from 1
              thou down to zero. I do use exact the same machine. I personally spent far
              more time than his did to bring things to sloe to 0.
              Regards,
              Anri.
                Look at run out is same around ~8-9 thou absolute disaster..
                I don't think the NEWEN CNC machine to be blamed, but who set the valve guide as the center with 8 thou off center error
                  I don't care if its the machine or the operator. Where is the QA? This is exactly why machine shops and engine rebuilders get a bad name, most want to tell you how their all first rate builders but Anri up in here straight walking the walk.
                    Sapote,
                    The guide has nothing to do you need to understand how it works and it
                    will be easier for you see it.(I can tell you got the comment from the guy in the
                    video and that gave you some food to chew) Again, trust me it has nothing
                    to do, I wish you are next to me when I am on top of machine so I can explain to
                    you and show you and then most important is I can demonstrate to you by going
                    Reverse-Machining...so you can see it with your own eyes how bad it will
                    go...Remember I made the correction on the same guide....
                    I looked earlier today at Serdi CNC valve seat machine and they talk about improving
                    the Concentricity ! Improving concentricity in 2023 ?... I made a video for us here
                    to share the data and the result personally I can do with the manual machine..Sapote
                    the machine I use is also Newen...lol
                    Regards,
                    Anri.
                      Oceansize,
                      Thank you for the kind words. I have noting to hide. Every Engine I build for
                      a customer comes with massive pictures and notes. To further up the quality
                      build I am in a process to make mounting hardware so I can put the engine
                      to do break-in procedure before being installed in the car, or I have option
                      for Engine Dyno as well.
                      Regards,
                      Anri.
                        Anri Thanks for posting his channel, some good info in there even if it isn't specifically BMW. I watched his 3x videos about concentricity and started watching his series about building the BBC, lots of food for thought that can be applied to any engine.
                        Email to [email protected]
                          Hill,
                          I don't know the guy at all it was just quick sample to demonstrate another
                          CNC-Newen type of a work. Nothing new to me in this machining world
                          any more...
                          I personally have done 50+ S54 cylinder heads, not counting the S38
                          S14, S65 etc.. I personally install guides, I personally hone them, I personally
                          cut the seat with 0-1" thou Concentricity. My standard is max 1' thou.
                          On the Serdi web site I watched their video of presentation on one of their
                          valve seat machine. In few days I will post and provide data in comparison
                          I have in mind.
                          Regards,
                          Anri.
                            Anri, What machine are you using?
                              Hill,
                              I will sent you PM.
                              I forgot to mention very important point, the concentricity must be taken from
                              the 45 degree angle not the top/last as I think the guy in the video I linked
                              took.
                              Regards,
                              Anri
                                Gents,
                                Too many engine projects are on the pipe line and had to concentrate
                                to get this project going on the road asap.
                                Engine is completed up and smooth running
                                After the initial start I have my own cup of tea procedure how to
                                break-in the motor and after 10mins engine was off.
                                All 6 spark plug out and checked the leak down and I am at "0"
                                also checking the lash quickly.
                                Well 0 does not exist !!!!!! but I am getting 1% leak down which
                                is absolute like how E46M3 rolled out from the assembly line back
                                in 2000 from Munich.
                                I have attached short videos on all 6 cylinders to share with you guys.
                                Again, this is for only 10min of engine break-in. Let the engine sees
                                1000 road miles and it will improve around 0.2-0.3% so I will end up
                                with around 0.5% leak down.
                                I do make sure before the engine goes back to the customer/road
                                I have great holding cylinder and head pressure. Its not nice the
                                Customer to check the leak down on its own and check the work
                                of the engine builder like what happened recently with our member.
                                Every engine I put together comes with 2 Years Unlimited miles Warranty.
                                Regards,
                                Anri
