Anyone running 18" ARC 8 wheels with a Dinan/Koni setup?
    If yes, can you please post pic/s of what that drop looks like? Plan on getting 18x9 / 18x10 setup. Thanks.
    Here is mine on Dinan/Konis, with dinan fixed front camber plates, and 18x9.5 +35 square EC-7s with 15mm spacers in the rear. These are 25" tires (255/35/18 front + 285/30/18 rear) so the gap you see is closed up with more normal rubber (factory sizing is 26"). Personally, I think the drop is perfect and I wouldn't want it any lower.
Name:	356051368_754736923065864_5201104679287610293_n.jpg?stp=cp6_dst-jpg&_nc_cat=111&cb=99be929b-59f725be&ccb=1-7&_nc_sid=5cd70e&_nc_ohc=z2wgRRMRMLoAX-ZoGUu&_nc_ht=scontent-den4-1.xx&oh=00_AfCr7L66G0ys5vLzAvOCwn62-IeMf3sUw8ybFZfw2b8
    Click image for larger version  Name:	356209866_754736936399196_5929369703660616976_n.jpg?stp=cp6_dst-jpg&_nc_cat=107&cb=99be929b-59f725be&ccb=1-7&_nc_sid=5cd70e&_nc_ohc=r-wmGzllaaYAX8FD0-u&_nc_ht=scontent-den4-1.xx&oh=00_AfDaajzCHzZ6CeM0V42X6KDKXOoRnvQEO_qOjcTf0BG Views:	0 Size:	171.2 KB ID:	224466
      What camber are you running up front with those plates?
        -2.8 degrees. They can add an additional -0.5 to the standard range of adjustment. Prior to installing these I was at -2.3 with pins pulled.
          Thanks so much. This helps alot.
            I was not running ARC8's but BBS's on Dinan/Koni. It's a subtle drop that just slightly closes that fender gap.
              Here you go, Dinan Spings, TCK Koni and Apex Arc8s 18x9F and 18x10R.
              Click image for larger version  Name:	1.jpg Views:	0 Size:	130.5 KB ID:	225089
              '06 IB/BLK 6SPD PN66072
