The plan is to relocate the SMG pump to the drug bin hopefully by the end of this year. I’ve been searching through the forums postings for some clues about routing the hydraulic lines. Should they be connected to the existing hard lines or should I completely remove the hard lines and run the new flexible hydraulic lines directly to the transmission actuators? It looks like the hydraulic lines that come with the relocation kits have male and female fittings to connect to the old hard lines, but the length of the lines are way too long and would be tough to stowaway and leave high places for air to collect. Plus the flexible sections of the old lines are getting fairly old and may be starting to deteriorate, very much the same way flexible brake lines will. It makes more sense to me to run the new lines directly to each of the actuators on the transmission. Plus the lines would need to be of different lengths and the lines could possibly be kept fairly flat or upwards inclined towards the pump to aid with air removal from the system. Am I playing to much into this? Looking at the Burkhart and the SMG Society websites they both offer flexible lines with both male and female fittings so I’m guessing they’re intending them to be connected to the old hard lines. I know that MRL Engineering will make any length braided line with any style of fittings needed, including banjo style.
Also, there is a difference with the inside diameter of the hydraulic lines. The original lines, which are basically brake lines, are much larger than the flexible lines offered for relocation. I know very little about hydraulics and the movement of liquids, but I’m hoping that someone here can help and tell me if the difference in diameter will make that much difference in the operation of the actuators? Too much resistance to the flow volume? Again, am I overthinking this?
Thanks
Thanks
