The actual BMW inner joint appears available as P/N:26117841003 at least according to FCP.
That cv part number you listed is for the driveshaft not axles. Bmw still owns the gkn license for the inner and outer axle joints that’s why there are no oe replacements on the market.
That cv part number you listed is for the driveshaft not axles. Bmw still owns the gkn license for the axle inner and outer axle joints that’s why there are no oe replacements on the market.
Buy a used axle, replace the bolts and repack with grease.
I feel like buying a used axle is a risk not worth taking. No guarantee a used axle doesn’t have the same wear on the bearings my current ones have.
I see bmw still sells new oem axles but that’s only if you can actually find them in stock. Only aftermarket options i really see are a few very cheap from rock auto with no reviews or really expensive rebuilt ones from driveshaft shop.
You can also get rebuilt upgraded units from Insane Shafts.
Redish Motorsport are BMW Specialist in Bristol who offer the Ultimate BMW experience when it comes to specialist procedures for your BMW M-Power Vehicle, at our fully equipped workshop in Bristol.
nothing. They wear less (I think…) and aren’t exposed to the exhaust heat as much. As far as I’m aware there are no replacements available for them.
fwiw I felt very little or no play in the outters when I was replacing the inners. Was surprising easy, and fast to do it. Of course, you need to drop the exhaust, etc.
Kind of what I figured you were going to say but I was hoping you had another link saved because I haven’t seen any outers anywhere either.
